Introducción
Be sure to remove the battery and SD card before opening the camera to get to the motherboard.
Partes
No se requieren partes.
Slide the bottom panel in the direction of the arrow on the panel.
  • Slide the bottom panel in the direction of the arrow on the panel.
Agregar Comentario
Pull/lift open the battery cover in the direction directly away from the camera.
  • Pull/lift open the battery cover in the direction directly away from the camera.
Agregar Comentario
Push the small gray plastic tab away from the battery in order to release the battery.
  • Push the small gray plastic tab away from the battery in order to release the battery.
Agregar Comentario
Pull the battery out of the camera.
  • Pull the battery out of the camera.
Agregar Comentario
Agregar Comentario
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Push down on the SD card next to the battery in order to release the SD card.
  • Push down on the SD card next to the battery in order to release the SD card.
  • Pull the SD memory card out of the camera in the same way that you would pull out the battery.
Agregar Comentario
Agregar Comentario
Agregar Comentario
Remove the two screws (2.2mm Philips) indicated.
  • Remove the two screws (2.2mm Philips) indicated.
Agregar Comentario
Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
  • Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
  • It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
Agregar Comentario
Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
  • Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
  • As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
Agregar Comentario
Remove the two screws (4.08mm" Philips) that are indicated in the picture.
  • Remove the two screws (4.08mm" Philips) that are indicated in the picture.
  • Flip the camera 180 degrees and remove the corresponding screws on the opposite side of the camera
Agregar Comentario
Remove the backing of the camera from the side opposite the screen
  • Remove the backing of the camera from the side opposite the screen
  • To make it easier for yourself, pull the screen outwards from the bottom of the camera, near the battery cover.
Agregar Comentario
Remove the small cover from near the top of the motherboard, using tweezers or forceps, as in the picture.
  • Remove the small cover from near the top of the motherboard, using tweezers or forceps, as in the picture.
Agregar Comentario
Unscrew the two screws (5.18mm Philips) indicated by the picture.
  • Unscrew the two screws (5.18mm Philips) indicated by the picture.
Agregar Comentario
Carefully remove the motherboard from the camera by grasping the sides and pulling upwards and then outwards.
  • Carefully remove the motherboard from the camera by grasping the sides and pulling upwards and then outwards.
Agregar Comentario
Conclusión
Zoe Hinck
Miembro Desde 12/04/12
29 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-19, Amido Spring 2012 Miembro de Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 816
