Introducción
A brief description on how to remove the logic board
Qué necesitas
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Lift up the black flap covering the ribbon cable with your hand
With the spudger, left green cable clamp
Gently remove ribbon cable from clamp
