Saltar al contenido principal
Palm v Battery Replacement
Qué necesitas
  1. Palm v Battery Replacement, Outer Case: paso 1, imagen 1 de 1
    • Lay device face down on surface.
  2. Palm v Battery Replacement: paso 2, imagen 1 de 2 Palm v Battery Replacement: paso 2, imagen 2 de 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Battery Replacement: paso 3, imagen 1 de 1
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Battery Replacement: paso 4, imagen 1 de 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Battery Replacement: paso 5, imagen 1 de 3 Palm v Battery Replacement: paso 5, imagen 2 de 3 Palm v Battery Replacement: paso 5, imagen 3 de 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
  6. Palm v Battery Replacement, Screen: paso 6, imagen 1 de 2 Palm v Battery Replacement, Screen: paso 6, imagen 2 de 2
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm v Battery Replacement: paso 7, imagen 1 de 3 Palm v Battery Replacement: paso 7, imagen 2 de 3 Palm v Battery Replacement: paso 7, imagen 3 de 3
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm v Battery Replacement: paso 8, imagen 1 de 2 Palm v Battery Replacement: paso 8, imagen 2 de 2
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull from the wire.
  9. Palm v Battery Replacement: paso 9, imagen 1 de 1
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
  10. Palm v Battery Replacement, Battery: paso 10, imagen 1 de 2 Palm v Battery Replacement, Battery: paso 10, imagen 2 de 2
    • Lay screen face down so the battery is facing upwards.
    • Cover the upper back portion of the device so the battery is the only exposed part.
  11. Palm v Battery Replacement: paso 11, imagen 1 de 1
    • Use the hairdryer to heat each side of the battery for at least 30 seconds.
  12. Palm v Battery Replacement: paso 12, imagen 1 de 2 Palm v Battery Replacement: paso 12, imagen 2 de 2
    • Using the tweezers or the spudger, pry off the battery from the screen.
    • If battery is not coming off, reheat sides and reattempt to remove.
Conclusión
3 personas más completaron esta guía.
Anthony Platt
Miembro Desde 02/09/10
66 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-25, Maness Winter 2010 Miembro de Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 37
Todo El Tiempo: 10,164
