Saltar al contenido principal
Palm m500 Battery Replacement
Qué necesitas
  1. Palm m500 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 Battery Replacement: paso 2, imagen 1 de 2 Palm m500 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 Battery Replacement: paso 3, imagen 1 de 3 Palm m500 Battery Replacement: paso 3, imagen 2 de 3 Palm m500 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 Battery Replacement, Battery: paso 4, imagen 1 de 3 Palm m500 Battery Replacement, Battery: paso 4, imagen 2 de 3 Palm m500 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 14-9, Forte Winter 2011 Miembro de Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 4,977
