Introducción
You will need to have a supply of AAA batteries for replacement. Can be found at most hardware and department stores. You can also order them online here
Press the latch on the battery door on the back of the device and pull outwards.
  • Press the latch on the battery door on the back of the device and pull outwards.
  • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
Agregar Comentario
Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
  • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
  • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
Agregar Comentario
Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
  • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
Agregar Comentario
Conclusión
Erik Thompson
Miembro Desde 04/10/11
31 Reputación
5 Guías creadas
Equipo
UW Stout, Team 1-3, Zhou Fall 2011 Miembro de UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Miembros
7 Guías creadas
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 760
