Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Agregar Comentario
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Agregar Comentario
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Agregar Comentario
The soldering iron heats up leads, wires, and everything else it touches that is metal.  Leaving it on too long may damage the board or burn you.
  • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
  • Desolder the speaker wires and solder the new speaker in its place.
  • The black and red wires are connected to the two solder bulbs in the yellow box.
Agregar Comentario
Conclusión
Gabe
Miembro Desde 23/01/11
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-21, Amido Winter 2011 Miembro de Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 489
