Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Agregar Comentario
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Agregar Comentario
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Agregar Comentario
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Agregar Comentario
The blue keys will either come off with the blue front case, or stay on the motherboard.
  • The blue keys will either come off with the blue front case, or stay on the motherboard.
Agregar Comentario
Conclusión
Gabe
Miembro Desde 23/01/11
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-21, Amido Winter 2011 Miembro de Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 474
