Saltar al contenido principal
Palm Treo 700P Motherboard Replacement
Qué necesitas
  1. Palm Treo 700P Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Palm Treo 700P Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Palm Treo 700P Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Motherboard Replacement: paso 2, imagen 1 de 2 Palm Treo 700P Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Motherboard Replacement, Back Case: paso 3, imagen 1 de 1
    • Remove the stylus from the phone.
  4. Palm Treo 700P Motherboard Replacement: paso 4, imagen 1 de 1
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Motherboard Replacement: paso 6, imagen 1 de 1
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Motherboard Replacement: paso 7, imagen 1 de 2 Palm Treo 700P Motherboard Replacement: paso 7, imagen 2 de 2
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 Palm Treo 700P Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 Palm Treo 700P Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Motherboard Replacement: paso 9, imagen 1 de 3 Palm Treo 700P Motherboard Replacement: paso 9, imagen 2 de 3 Palm Treo 700P Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Motherboard Replacement: paso 10, imagen 1 de 2 Palm Treo 700P Motherboard Replacement: paso 10, imagen 2 de 2
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Motherboard Replacement: paso 11, imagen 1 de 3 Palm Treo 700P Motherboard Replacement: paso 11, imagen 2 de 3 Palm Treo 700P Motherboard Replacement: paso 11, imagen 3 de 3
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Conclusión
Ivan
Miembro Desde 04/29/12
11 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-37, Regan Spring 2012 Miembro de Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 793
