Introducción
This is a guide that indicates how to replace a faulty microphone for the Palm Treo 680.
Remove the battery cover by pressing on the small rectangular button location the back of the phone. Remove the battery cover by pressing on the small rectangular button location the back of the phone.
  • Remove the battery cover by pressing on the small rectangular button location the back of the phone.
Agregar Comentario
Remove the battery by pulling it out toward you.
  • Remove the battery by pulling it out toward you.
Agregar Comentario
Unscrew the 0.266 inch top-left screw with a T6 Torx Screwdriver. Be sure to remove the stylus in order to access the screw.
  • Unscrew the 0.266 inch top-left screw with a T6 Torx Screwdriver.
  • Be sure to remove the stylus in order to access the screw.
Use a T5 Torx screwdriver instead of a T6. T6 is too big.
Rhebakah Thomas - Contestar
I found T5 too large as well. T4 seeems to work
Absent Minded Professor - Contestar
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device. Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
  • Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device.
  • Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
    • If there is a red Palm sticker covering the screw, just puncture it to access the screw.
Agregar Comentario
Remove the remaining two 0.266 inch screws at the bottom of the device.
  • Remove the remaining two 0.266 inch screws at the bottom of the device.
Agregar Comentario
Turn the phone 90 degrees to the right, so the screen is facing the right side. Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone. Separate the covers from the left side of the device as indicated in the picture. The right side contains orange ribbons that are easily damaged.
  • Turn the phone 90 degrees to the right, so the screen is facing the right side.
  • Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone.
  • Separate the covers from the left side of the device as indicated in the picture. The right side contains orange ribbons that are easily damaged.
Agregar Comentario
Using a pair of tweezers, grasp the blue rubber microphone. Pull the rubber microphone up and back to remove it.
  • Using a pair of tweezers, grasp the blue rubber microphone.
  • Pull the rubber microphone up and back to remove it.
  • Now you have successfully removed the microphone.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Maiya123
Miembro Desde 22/10/09
36 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 6-4, Maness Fall 2009 Miembro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 4,000
