Saltar al contenido principal
Palm Treo 680 Keyboard Replacement
Qué necesitas
  1. Palm Treo 680 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Palm Treo 680 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Keyboard Replacement, Back Panel: paso 3, imagen 1 de 2 Palm Treo 680 Keyboard Replacement, Back Panel: paso 3, imagen 2 de 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Keyboard Replacement: paso 4, imagen 1 de 2 Palm Treo 680 Keyboard Replacement: paso 4, imagen 2 de 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Keyboard Replacement: paso 6, imagen 1 de 3 Palm Treo 680 Keyboard Replacement: paso 6, imagen 2 de 3 Palm Treo 680 Keyboard Replacement: paso 6, imagen 3 de 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Keyboard Replacement, Motherboard: paso 7, imagen 1 de 2 Palm Treo 680 Keyboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Slide the slim metal plate upwards until it disconnects from the motherboard.
    • DO NOT bend or crinkle this metal plate. It will be VERY DIFFICULT, IF NOT IMPOSSIBLE, to slide it back into place when you are re-assembling if you bend or crinkle this metal plate.
  8. Palm Treo 680 Keyboard Replacement: paso 8, imagen 1 de 2 Palm Treo 680 Keyboard Replacement: paso 8, imagen 2 de 2
    • Locate the orange ribbon that connects the screen to the motherboard.
    • Use tweezers to peel off the small piece of tape over the orange ribbon connector.
  9. Palm Treo 680 Keyboard Replacement: paso 9, imagen 1 de 2 Palm Treo 680 Keyboard Replacement: paso 9, imagen 2 de 2
    • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
    • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  10. Palm Treo 680 Keyboard Replacement: paso 10, imagen 1 de 3 Palm Treo 680 Keyboard Replacement: paso 10, imagen 2 de 3 Palm Treo 680 Keyboard Replacement: paso 10, imagen 3 de 3
    • Carefully turn the phone over so the screen is face up.
    • Locate the other orange ribbon that connects the motherboard to the faceplate.
    • Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
    • Separate the motherboard and faceplate of the Palm Treo.
  11. Palm Treo 680 Keyboard Replacement, Keyboard: paso 11, imagen 1 de 2 Palm Treo 680 Keyboard Replacement, Keyboard: paso 11, imagen 2 de 2
    • Locate the backside of the Treo's faceplate.
    • Remove the two screws using the T6 Torx screwdriver.
  12. Palm Treo 680 Keyboard Replacement: paso 12, imagen 1 de 2 Palm Treo 680 Keyboard Replacement: paso 12, imagen 2 de 2
    • Take off the plastic back panel, to gain access to the rubber keys of the keyboard.
    • Push on the keys and function bar from the front of the Treo. They should all pop right out.
Conclusión
Una persona más ha completado esta guía.
Maiya123
Miembro Desde 10/22/09
51 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-4, Maness Fall 2009 Miembro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,815
