Introducción
A guide for removing and replacing the phone's microphone.
Position the phone so the screen faces down.
  • Position the phone so the screen faces down.
  • Remove the stylus found on the back of the phone.
Agregar Comentario
To remove the battery cover, hold down the button in the middle of the phone's back.
  • To remove the battery cover, hold down the button in the middle of the phone's back.
  • Slide the cover down to remove. Set the cover aside.
Agregar Comentario
Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
  • Lift the edge of the battery, separating contact points, and pull out as pictured.
Agregar Comentario
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • This will uncover a screw that will be removed in the next step.
Agregar Comentario
Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver. Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver. Pull out antenna.
  • Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
  • Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
  • Pull out antenna.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
  • Pry the back cover off using a spudger or similar tool.
  • The back cover is attached by several small clips on the inside.
Agregar Comentario
Unclip the gray tab. Pull out the orange ribbon cable. Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
  • Unclip the gray tab.
  • Pull out the orange ribbon cable.
  • Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
Agregar Comentario
Pull off the mother board. Install replacement or repaired motherboard, reversing steps above.
  • Pull off the mother board.
  • Install replacement or repaired motherboard, reversing steps above.
Agregar Comentario
Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
Agregar Comentario
Pull off the circuit board.
  • Pull off the circuit board.
Agregar Comentario
Remove the keypad for cleaning or replacing.
  • Remove the keypad for cleaning or replacing.
Agregar Comentario
Place the circuit board with the microphone facing up.
  • Place the circuit board with the microphone facing up.
Agregar Comentario
The microphone should be able to pop off easily using your finger. The microphone should be able to pop off easily using your finger.
  • The microphone should be able to pop off easily using your finger.
Agregar Comentario
Conclusión
cgood
Miembro Desde 28/10/09
116 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 19-3, Maness Fall 2009 Miembro de Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 4,365
