Introducción
These steps will allow you to replace the screen with a new one.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Agregar Comentario
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Agregar Comentario
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Agregar Comentario
Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
  • Using a T6 Torx Screwdriver, remove the two screws.
  • The motherboard will now be loose from the front case.
Agregar Comentario
The screen is connected to the phone with an orange data cable.
  • The screen is connected to the phone with an orange data cable.
  • Slide the spudger as close to the connection as possible.
  • Gently pull the spudger up and the cable should come out of the socket.
Agregar Comentario
Once the cable is unplugged, you can remove the screen from the body. Once the cable is unplugged, you can remove the screen from the body.
  • Once the cable is unplugged, you can remove the screen from the body.
Agregar Comentario
Conclusión
Clement Poisson
Miembro Desde 26/01/10
24 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,046
