Introducción
After you have taken off the back case, the front case can also be removed to help you complete other teardown guides.
Partes
No se requieren partes.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Agregar Comentario
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Agregar Comentario
Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
  • Using a T6 Torx Screwdriver, remove the two screws.
  • The motherboard will now be loose from the front case.
Agregar Comentario
Conclusión
Michael Polka
Miembro Desde 27/01/10
22 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,480
