Introducción
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Agregar Comentario
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Agregar Comentario
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Agregar Comentario
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Agregar Comentario
Lift up the silver casing.
  • Lift up the silver casing.
  • Careful! The casing is connected to the body. Pull the casing up.
Agregar Comentario
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Agregar Comentario
Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone.
  • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Agregar Comentario
Using the flat end of the spudger, lift the metal case off of the camera. Using the flat end of the spudger, lift the metal case off of the camera.
  • Using the flat end of the spudger, lift the metal case off of the camera.
Agregar Comentario
Slide the flat end of the spudger between the printed circuit board and metal holder. Pop the camera up Pop the camera up
  • Slide the flat end of the spudger between the printed circuit board and metal holder.
  • Pop the camera up
Agregar Comentario
Conclusión
Clement Poisson
Miembro Desde 26/01/10
24 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,479
