Introducción
Opening up the phone to reveal the guts.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Agregar Comentario
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Agregar Comentario
Conclusión
Clement Poisson
Miembro Desde 26/01/10
24 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,591
