Introducción
An unresponsive power button is a very common problem. Typically, this problem occurs when the solder between the power button and the motherboard weakens. For more information and other fixing alternatives see the link below:
Qué necesitas
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Flip the motherboard so that the black rubber cover faces upward. The power switch is in the top right corner.
Remove the button with a soldering iron.
For soldering instructions, view the Soldering Guide.
