Saltar al contenido principal
Palm TX Buttons and Connector Assembly Replacement
Qué necesitas
  1. Palm TX Buttons and Connector Assembly Replacement, Back Panel: paso 1, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement, Back Panel: paso 1, imagen 2 de 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Buttons and Connector Assembly Replacement: paso 2, imagen 1 de 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Buttons and Connector Assembly Replacement: paso 3, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement: paso 3, imagen 2 de 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Buttons and Connector Assembly Replacement: paso 4, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement: paso 4, imagen 2 de 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Buttons and Connector Assembly Replacement: paso 5, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Buttons and Connector Assembly Replacement, Battery Pack: paso 6, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement, Battery Pack: paso 6, imagen 2 de 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Buttons and Connector Assembly Replacement, Motherboard: paso 7, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement, Motherboard: paso 7, imagen 2 de 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Buttons and Connector Assembly Replacement: paso 8, imagen 1 de 2 Palm TX Buttons and Connector Assembly Replacement: paso 8, imagen 2 de 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
  9. Palm TX Buttons and Connector Assembly Replacement, Display: paso 9, imagen 1 de 1
    • Orient the device sideways, as shown in the picture.
    • Lightly push the front of the display to separate it from the front panel.
    • The battery in the picture will not be attached to the device at this point.
  10. Palm TX Buttons and Connector Assembly Replacement, Buttons and Connector Assembly: paso 10, imagen 1 de 1
    • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
    • It may take some manipulation to remove the screws.
  11. Palm TX Buttons and Connector Assembly Replacement: paso 11, imagen 1 de 1
    • Lift the button and connector assembly from the front panel.
Conclusión
Equipo
Cal Poly, Team 1-15, Amido Winter 2011 Miembro de Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Miembros
7 Guías creadas
Un comentario
Where can you buy one of these?
Sean Madawala - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 1,631
