Saltar al contenido principal
Palm Pre Speaker Replacement
Qué necesitas
  1. Palm Pre Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Palm Pre Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
  4. Palm Pre Speaker Replacement: paso 4, imagen 1 de 2 Palm Pre Speaker Replacement: paso 4, imagen 2 de 2
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
  5. Palm Pre Speaker Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
  6. Palm Pre Speaker Replacement: paso 6, imagen 1 de 1
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
Conclusión
noha
Miembro Desde 04/12/12
139 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 7-31, Maness Spring 2012 Miembro de Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,168
