Saltar al contenido principal
Palm IIIx Motherboard Assembly Replacement
Qué necesitas
  1. Palm IIIx Motherboard Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Motherboard Assembly Replacement: paso 2, imagen 1 de 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Motherboard Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Motherboard Assembly Replacement, Motherboard Assembly: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Motherboard Assembly Replacement: paso 5, imagen 1 de 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Motherboard Assembly Replacement: paso 6, imagen 1 de 1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Motherboard Assembly Replacement: paso 7, imagen 1 de 2 Palm IIIx Motherboard Assembly Replacement: paso 7, imagen 2 de 2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Motherboard Assembly Replacement: paso 8, imagen 1 de 1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Motherboard Assembly Replacement: paso 9, imagen 1 de 1
    • Separate the motherboard from the screen.
  10. Palm IIIx Motherboard Assembly Replacement: paso 10, imagen 1 de 1
    • Now the motherboard assembly can be replaced successfully.
Conclusión
Una persona más ha completado esta guía.
Ben Johnson
Miembro Desde 01/26/10
22 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-43, Regan Winter 2010 Miembro de Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 3,072
