Introducción
Going deaf? Perhaps it's just the speaker...replace it! Use this guide to replace the speaker on Sony's PSP 2000.
Place PSP face down, so that the UMD Drive is facing upwards. Locate the battery door and open. Remove the battery from inside.
  • Place PSP face down, so that the UMD Drive is facing upwards.
  • Locate the battery door and open.
  • Remove the battery from inside.
Agregar Comentario
This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.  According to the FTC removing this will not void your warranty.
  • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
  • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
  • Remove the sticker using the PSP Opening Tools.
  • Under the sticker is a 5mm Phillips screw needed in the next step.
Agregar Comentario
Remove four 5 mm Phillips from the case. If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  • Remove four 5 mm Phillips from the case.
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the following screws from around the bezel: Two 4 mm Phillips
  • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
  • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
Agregar Comentario
Gently pry the front bezel away from the casing using a PSP opening tool. Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
  • Gently pry the front bezel away from the casing using a PSP opening tool.
  • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
  • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Agregar Comentario
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar.
  • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
  • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
Agregar Comentario
With the home bar out of the way, gently pry up the display using the opening tools. There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing. Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • With the home bar out of the way, gently pry up the display using the opening tools.
  • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
  • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • Gently lift out the display.
Agregar Comentario
Use the opening tools to press the tab on the left-hand side of the speaker to release it. Be careful not to puncture the speaker in the process.
  • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
  • Be careful not to puncture the speaker in the process.
  • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
espinks
Miembro Desde 18/10/09
2,576 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-3, Maness Fall 2009 Miembro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Miembros
12 Guías creadas
What about the other speaker? How to replace?
felipeavatar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 6
Últimos 30 Días: 36
Todo El Tiempo: 8,638
