Introducción
Is your logic board acting illogical? Fix it!
Place PSP face down, so that the UMD Drive is facing upwards. Locate the battery door and open. Remove the battery from inside.
  • Place PSP face down, so that the UMD Drive is facing upwards.
  • Locate the battery door and open.
  • Remove the battery from inside.
Agregar Comentario
This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.  According to the FTC removing this will not void your warranty.
  • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
  • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
  • Remove the sticker using the PSP Opening Tools.
  • Under the sticker is a 5mm Phillips screw needed in the next step.
Agregar Comentario
Remove four 5 mm Phillips from the case. If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  • Remove four 5 mm Phillips from the case.
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
Agregar Comentario
Remove the following screws from around the bezel: Two 4 mm Phillips
  • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
  • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
Agregar Comentario
Gently pry the front bezel away from the casing using a PSP opening tool. Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
  • Gently pry the front bezel away from the casing using a PSP opening tool.
  • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
  • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar.
  • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
  • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
Agregar Comentario
With the home bar out of the way, gently pry up the display using the opening tools. There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing. Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • With the home bar out of the way, gently pry up the display using the opening tools.
  • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
  • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • Gently lift out the display.
Agregar Comentario
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP. Slide off the left trigger along with the plastic bracket underneath. Carefully pry off left trigger button using opening tools.
  • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
  • Slide off the left trigger along with the plastic bracket underneath.
  • Carefully pry off left trigger button using opening tools.
  • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
Agregar Comentario
Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally. Gently remove the memory card slot by pulling it straight out.
  • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
  • Gently remove the memory card slot by pulling it straight out.
Agregar Comentario
Use the opening tools to press the tab on the left-hand side of the speaker to release it. Be careful not to puncture the speaker in the process.
  • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
  • Be careful not to puncture the speaker in the process.
  • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
Agregar Comentario
Remove the following four connections:
  • Remove the following four connections:
    • Two ribbon cables -- flip up latch and remove horizontally.
    • One wire clamp -- use an opening tool to pry it up vertically.
    • One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
  • The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector.
Agregar Comentario
Remove metal shields by gently lifting them with an opening tool. Remove metal shields by gently lifting them with an opening tool.
  • Remove metal shields by gently lifting them with an opening tool.
Agregar Comentario
Double-check to make sure that all connections to the board are unplugged in order to avoid damage to your PSP. Using an opening tool, delicately raise the logic board from its base. Using an opening tool, delicately raise the logic board from its base.
  • Double-check to make sure that all connections to the board are unplugged in order to avoid damage to your PSP.
  • Using an opening tool, delicately raise the logic board from its base.
Agregar Comentario
Conclusión
20 personas más completaron esta guía.
espinks
Miembro Desde 18/10/09
2,576 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-3, Maness Fall 2009 Miembro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Miembros
12 Guías creadas
How do I know whether my Logic Board is functioning properly or not?
Alvin Wijaya - Contestar
how can I change that little refill on the motherboard
Dmytro Yantsur - Contestar
how-do-i-repair-the-screen-conntors
james - Contestar
My psp is not turning on when battery is inserted even when plugged to electricity...and again if the battery is inserted to it the charging light turns on..Pls help m
Farotide David - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 46
Últimos 30 Días: 218
Todo El Tiempo: 31,984
