Saltar al contenido principal
PSP 2000 Front Casing Replacement
Qué necesitas
  1. PSP 2000 Front Casing Replacement, Battery: paso 1, imagen 1 de 3 PSP 2000 Front Casing Replacement, Battery: paso 1, imagen 2 de 3 PSP 2000 Front Casing Replacement, Battery: paso 1, imagen 3 de 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: paso 2, imagen 1 de 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: paso 3, imagen 1 de 2 PSP 2000 Front Casing Replacement: paso 3, imagen 2 de 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: paso 4, imagen 1 de 2 PSP 2000 Front Casing Replacement: paso 4, imagen 2 de 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Front Casing Replacement: paso 5, imagen 1 de 2 PSP 2000 Front Casing Replacement: paso 5, imagen 2 de 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Conclusión
13 personas más completaron esta guía.
pepe32290
Miembro Desde 10/19/09
1,573 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-3, Maness Fall 2009 Miembro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Miembros
35 Guías creadas
Un comentario
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 59
Ultimos 30 días: 212
Todo El Tiempo: 26,254
