Introducción
This guide will show you how to remove and replace your PSP speakers.
Qué necesitas
The Button Board, at the base of the LCD Screen, is held by two clips.
Pry these clips over the nubs using a PSP opening tool. This will release the clips.
The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
Both of these latches are the black pieces.
Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
Remove the screws on the top and bottom of the frame. Be sure to keep track of where you took each screw out of.
9 personas más completaron esta guía.
