Saltar al contenido principal
OontZ Angle 3 Speaker Replacement
Qué necesitas
  1. OontZ Angle 3 Speaker Replacement, Back Case: paso 1, imagen 1 de 3 OontZ Angle 3 Speaker Replacement, Back Case: paso 1, imagen 2 de 3 OontZ Angle 3 Speaker Replacement, Back Case: paso 1, imagen 3 de 3
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: paso 3, imagen 1 de 2 OontZ Angle 3 Speaker Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: paso 4, imagen 1 de 2 OontZ Angle 3 Speaker Replacement, Speaker: paso 4, imagen 2 de 2
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: paso 5, imagen 1 de 2 OontZ Angle 3 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: paso 6, imagen 1 de 2 OontZ Angle 3 Speaker Replacement: paso 6, imagen 2 de 2
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
Conclusión
10 personas más completaron esta guía.
Mason Hollander
Miembro Desde 01/20/16
1,375 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 15-6, Remmell Spring 2016 Miembro de USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
4 Miembros
4 Guías creadas
7 comentarios
Where do you buy replacement speakers?
michalfiona - Contestar
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
Sharina Uadan - Contestar
Where can i buy the replacement speakers
Anil Meda - Contestar
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 70
Todo El Tiempo: 7,997
