Saltar al contenido principal
Olympus Stylus 725 SW Lens Replacement
Qué necesitas
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 1, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 1, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 1, imagen 3 de 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  2. Olympus Stylus 725 SW Lens Replacement: paso 2, imagen 1 de 2 Olympus Stylus 725 SW Lens Replacement: paso 2, imagen 2 de 2
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: paso 3, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: paso 3, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: paso 3, imagen 3 de 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: paso 4, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: paso 4, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: paso 4, imagen 3 de 3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. Olympus Stylus 725 SW Lens Replacement: paso 5, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement: paso 5, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement: paso 5, imagen 3 de 3
    • After removing all four of the screws, pry the side covers off of the camera.
  6. Olympus Stylus 725 SW Lens Replacement, Lens: paso 6, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement, Lens: paso 6, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement, Lens: paso 6, imagen 3 de 3
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
  7. Olympus Stylus 725 SW Lens Replacement: paso 7, imagen 1 de 3 Olympus Stylus 725 SW Lens Replacement: paso 7, imagen 2 de 3 Olympus Stylus 725 SW Lens Replacement: paso 7, imagen 3 de 3
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
  8. Olympus Stylus 725 SW Lens Replacement: paso 8, imagen 1 de 2 Olympus Stylus 725 SW Lens Replacement: paso 8, imagen 2 de 2
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
Conclusión
Bobby Hodges
Miembro Desde 04/18/10
49 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 33-71, Johann Spring 2010 Miembro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,434
