Introducción
This guide will take you through all the steps to sucessfully install a new logic board to your Olympus D590 camera.
Partes
No se requieren partes.
Flip camera so you are looking at the bottom.
  • Flip camera so you are looking at the bottom.
  • Unscrew all 5 base plate screws.
Agregar Comentario
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Agregar Comentario
Unscrew the single screw located next to the battery slot.
  • Unscrew the single screw located next to the battery slot.
Agregar Comentario
Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
  • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
  • Lift the rubber plate exposing the ports beneath.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unscrew the 2 screws next to the USB and AC ports.
  • Unscrew the 2 screws next to the USB and AC ports.
Agregar Comentario
Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Agregar Comentario
Pull off the faceplate to reveal the inside of the camera.
  • Pull off the faceplate to reveal the inside of the camera.
  • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
Agregar Comentario
Unscrew all 4 circled screws.
  • Unscrew all 4 circled screws.
Agregar Comentario
The logic board should now be loose and easily liftable.
  • The logic board should now be loose and easily liftable.
  • DO NOT lift the board out completely the wiring that is still connected must be disconnected before proceeding.
Agregar Comentario
Disconnect the 3 wiring strips from the device by gently pulling with tweasers from the base of the strip. Do not use sharp tweasers because the wiring might tear. Make sure to use small force so the wiring is not damaged.  It may help to gently wiggle the tape.
  • Disconnect the 3 wiring strips from the device by gently pulling with tweasers from the base of the strip.
  • Do not use sharp tweasers because the wiring might tear.
  • Make sure to use small force so the wiring is not damaged. It may help to gently wiggle the tape.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Sara
Miembro Desde 15/04/10
84 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,607
