Introducción
We will show how to tear down to and remove the LCD screen.
Unscrew all immediately visible screws on the body of the camera. Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
  • Unscrew all immediately visible screws on the body of the camera.
  • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
Agregar Comentario
Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera.
  • Use the plastic opening tool to separate the back cover from the camera.
Agregar Comentario
With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen. Unscrew both of these screws. Unscrew both of these screws.
  • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
  • Unscrew both of these screws.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the LCD screen over.
  • Flip the LCD screen over.
Agregar Comentario
Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
  • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
Agregar Comentario
Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard. Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
  • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
Agregar Comentario
The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera.
  • The LCD screen housing should now be free of the camera.
Agregar Comentario
Conclusión
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 3
Todo El Tiempo: 941
