Introducción
A bad board may be responsible for a overall dead camera operations. If the board is malfunctioning it must be replaced to fix the problem. This guide involves multiple steps including soldering and other difficult steps.
Partes
No se requieren partes.
Remove all of the screws that hold the back plate in place. Unscrew the 4mm screw that is directly to the right of the viewfinder. On the base,
  • Remove all of the screws that hold the back plate in place.
    • Unscrew the 4mm screw that is directly to the right of the viewfinder.
    • On the base,
      • Unscrew the 3mm screw in the top left corner.
      • Unscrew all four 3mm screws under the battery cover.
    • Unscrew the 3mm screw on the right side panel.
    • Unscrew the two 2mm screws on the left side panel.
    • The bullets apply to the three pictures on the step.
Agregar Comentario
Now remove the back panel completely. Gently rock the 2 ribbon cables from their sockets.
  • Now remove the back panel completely.
    • Gently rock the 2 ribbon cables from their sockets.
    • With metal tweezers, grasp and pull white cable out of its clip.
Agregar Comentario
On the surface of the board,
  • On the surface of the board,
    • Peel off the plastic sheets on the board.
    • Unscrew 2-3mm from the board itself.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Loosen the ribbon cables from the board. 1-Directly below the viewfinder. 2-At the Base of the board.
  • Loosen the ribbon cables from the board.
    • 1-Directly below the viewfinder.
    • 2-At the Base of the board.
    • 3-At the top right near the selector wheel. 1 on top of the board 2 on the underside.
    • 1-The center of the board, above the central hole.
  • With metal tweezers, remove the two white plastic clips from their sockets one on the base of the board and the other on the surface.
Agregar Comentario
Remove the single 3mm ground screw attached to the camera body
  • Remove the single 3mm ground screw attached to the camera body
Agregar Comentario
The mother board has two solder connections that need to be undone to remove the board
  • The mother board has two solder connections that need to be undone to remove the board
  • Don't attempt to unsolder the joints without previous knowledge of soldering
  • When soldering avoiding touching any other components with the iron
Agregar Comentario
Once we have the mother board removed it can be replaced with a new board.
  • Once we have the mother board removed it can be replaced with a new board.
  • While the mother board is removed it is possible to get further into the camera itself to make more repairs.
Agregar Comentario
Conclusión
Mason Morgan
Miembro Desde 05/04/11
115 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-33, Maness Spring 2011 Miembro de Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 9
Todo El Tiempo: 2,836
