Introducción
LCD's can stop working, get cracked or for any number of reasons need to be replaced. This guide shows the relatively easy process for replacing the LCD on this camera. The process involves removing the back panel from the camera and a couple of ribbon cables.
Partes
No se requieren partes.
Remove all the screws holding the back plate in place. Unscrew the 4mm screw that is directly to the right of the viewfinder. On the base:
  • Remove all the screws holding the back plate in place.
    • Unscrew the 4mm screw that is directly to the right of the viewfinder.
    • On the base:
      • Unscrew 3mm screw in the top left corner
      • Unscrew 4-3mm screws under the battery cover
    • Unscrew 1-3mm screw on the right side panel.
    • Unscrew 2-2mm screws on the left side panel.
    • The bullets on this step apply to all 3 pictures included it this step.
The bullets on this step apply to the 3 pictures included in this step
Cynthia - Contestar
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Now we remove the back panel completely. 2 ribbon cables can be gently rocked out of their sockets
  • Now we remove the back panel completely.
    • 2 ribbon cables can be gently rocked out of their sockets
    • Use metal tweezers to grasp and pull the white cable out of its clip
Agregar Comentario
Peel the black tape off of the back surface of the LCD Unscrew 4-3mm screws, on the LCD bracket Unscrew 2-2mm screws from the top of the bracket
  • Peel the black tape off of the back surface of the LCD
  • Unscrew 4-3mm screws, on the LCD bracket
  • Unscrew 2-2mm screws from the top of the bracket
  • Lastly using a spudger, pop the LCD out of the camera back plate.
  • When the bracket comes off, be aware that the buttons from the top section will fall out of place if the plate is inverted.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Mason Morgan
Miembro Desde 05/04/11
115 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-33, Maness Spring 2011 Miembro de Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 8
Todo El Tiempo: 2,505
