Introducción
Use this guide to remove the frame from the screen on your OLPC XO 4.0 Touch.
Partes
No se requieren partes.
Turn the laptop upside-down, with the handle facing away from you.
  • Turn the laptop upside-down, with the handle facing away from you.
Agregar Comentario
Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  • Pull the lock tabs towards the green outer edges of the laptop.
  • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
Agregar Comentario
Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
  • Lift up on the middle of the battery to remove it from the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side. Rotate the screen 180° and remove the other two screws. You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
  • Rotate the screen 180° and remove the other two screws.
  • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
Agregar Comentario
Remove the green side panel by pressing down on the small green button on the top and sliding the panel up. Repeat the step above for the panel on the other side. Repeat the step above for the panel on the other side.
  • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
  • Repeat the step above for the panel on the other side.
Agregar Comentario
Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
  • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
  • Gently lift up the lower part of the frame and pull it down to free the screen frame.
Agregar Comentario
Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame. Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
Agregar Comentario
Conclusión
Ji Kim
Miembro Desde 25/01/13
18 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-29, Amido Winter 2013 Miembro de Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 108
