Herramientas
No se requieren herramientas.
Partes
Place the laptop upside down with the handle away from you.
  • Place the laptop upside down with the handle away from you.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Slide the tabs out, towards the green edges,  to show the open lock symbol.
  • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
Agregar Comentario
Lift the middle of the battery to remove it. Lift the middle of the battery to remove it. Lift the middle of the battery to remove it.
  • Lift the middle of the battery to remove it.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Daniel Nishi
Miembro Desde 05/10/12
39 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-19, Amido Fall 2012 Miembro de Cal Poly, Team 3-19, Amido Fall 2012
CPSU-AMIDO-F12S3G19
6 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,163
