Partes
No se requieren partes.
Flip over the turntable and remove the nine screws on the outer edges.
  • Flip over the turntable and remove the nine screws on the outer edges.
Agregar Comentario
Find the audio jacks located on the back side of the turntable. Remove the screw located in between the right and left audio jacks.
  • Find the audio jacks located on the back side of the turntable.
  • Remove the screw located in between the right and left audio jacks.
Agregar Comentario
Remove the back cover by pulling it apart.
  • Remove the back cover by pulling it apart.
Agregar Comentario
Remove the grounding hardware located next to the audio jacks.
  • Remove the grounding hardware located next to the audio jacks.
Agregar Comentario
Remove the ground screw and washers. Remove the ground screw and washers.
  • Remove the ground screw and washers.
Agregar Comentario
Remove the remaining nut and washer.
  • Remove the remaining nut and washer.
Agregar Comentario
Remove the screw located on the back panel of the audio jack housing.
  • Remove the screw located on the back panel of the audio jack housing.
Agregar Comentario
Remove the screw that connects the audio jacks to the biggest circuit board via wire. Remove the screw that connects the audio jacks to the biggest circuit board via wire. Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
Agregar Comentario
Gently pull out the audio input jacks from the audio input housing.
  • Gently pull out the audio input jacks from the audio input housing.
Agregar Comentario
Conclusión
Nikolai
Miembro Desde 12/10/11
161 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-14, Regan Fall 2011 Miembro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,029
