Introducción
Splitting the case of the Mifi 2200 is necessary to be able access the internal parts. This is how to go about that.
Partes
No se requieren partes.
Remove the rear cover by pressing down on the cover and pulling it away from the device.
  • Remove the rear cover by pressing down on the cover and pulling it away from the device.
Agregar Comentario
Place your finger on the back of the battery located near the edge of the device.
  • Place your finger on the back of the battery located near the edge of the device.
  • Push your finger into the battery and lift up to pop the battery out of the device.
Agregar Comentario
Using a metal spudger, pry open the device around the seam between the front and back cover.
  • Using a metal spudger, pry open the device around the seam between the front and back cover.
  • It may be difficult to split apart, so use force with caution.
  • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
Agregar Comentario
Once the seal has been broken all the way around, open the cases using your hands.
  • Once the seal has been broken all the way around, open the cases using your hands.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Justin Russo
Miembro Desde 15/04/12
196 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-36, Maness Spring 2012 Miembro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Miembros
5 Guías creadas
If case gets damaged, is there a place to but the case
Snehraj Merchant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 14
Todo El Tiempo: 1,342
