Saltar al contenido principal
Novatel MiFi 2200 Battery Replacement
Qué necesitas
  1. Novatel MiFi 2200 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Battery Replacement: paso 2, imagen 1 de 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Battery Replacement: paso 3, imagen 1 de 1
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  4. Novatel MiFi 2200 Battery Replacement: paso 4, imagen 1 de 2 Novatel MiFi 2200 Battery Replacement: paso 4, imagen 2 de 2
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
Conclusión
Charge your new battery and you are ready to use your Mifi again.
Una persona más ha completado esta guía.
Carissah
Miembro Desde 04/15/12
147 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-36, Maness Spring 2012 Miembro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,014
