Introducción
Connection problems may occur with this device due to a faulty or broken antenna. You can contact your service provider or search online to purchase a new antenna to replace. This guide give instructions on how to replace antenna.
Partes
No se requieren partes.
Remove the rear cover by pressing down on the cover and pulling it away from the device.
  • Remove the rear cover by pressing down on the cover and pulling it away from the device.
Agregar Comentario
Place your finger on the back of the battery located near the edge of the device.
  • Place your finger on the back of the battery located near the edge of the device.
  • Push your finger into the battery and lift up to pop the battery out of the device.
Agregar Comentario
Using a metal spudger, pry open the device around the seam between the front and back cover.
  • Using a metal spudger, pry open the device around the seam between the front and back cover.
  • It may be difficult to split apart, so use force with caution.
  • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
Agregar Comentario
Once the seal has been broken all the way around, open the cases using your hands.
  • Once the seal has been broken all the way around, open the cases using your hands.
Agregar Comentario
To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
Agregar Comentario
Carefully pull out the antenna along the edge of the device.
  • Carefully pull out the antenna along the edge of the device.
  • There is adhesive applied to the antenna, so it may not easily detach.
Agregar Comentario
Reconnect your new antenna to the circuit board in the same position described in step 3.
  • Reconnect your new antenna to the circuit board in the same position described in step 3.
Agregar Comentario
Re-lay antenna around the edge and over the adhesive.
  • Re-lay antenna around the edge and over the adhesive.
  • The antenna can be fitted back into several small recesses along the groove that it was originally inside.
Agregar Comentario
Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed. Snap the two halves together along the adhesive line to reconnect it as it previously was. Snap the two halves together along the adhesive line to reconnect it as it previously was.
  • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
  • Snap the two halves together along the adhesive line to reconnect it as it previously was.
Agregar Comentario
Conclusión
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
Carissah
Miembro Desde 15/04/12
147 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-36, Maness Spring 2012 Miembro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 9
Todo El Tiempo: 157
