Introducción
This guide will teach the user how to install a new motor for the device.
Qué necesitas
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
Use a Phillips #0 screwdriver to remove the two 2.5mm screws connecting the motor to the fan base.
Remove the motor from the fan base.
