Saltar al contenido principal
Nortel Networks i2004 IP Circuit Board Replacement
Qué necesitas
  1. Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: paso 1, imagen 1 de 3 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: paso 1, imagen 2 de 3 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: paso 1, imagen 3 de 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Circuit Board Replacement: paso 2, imagen 1 de 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Circuit Board Replacement: paso 3, imagen 1 de 2 Nortel Networks i2004 IP Circuit Board Replacement: paso 3, imagen 2 de 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Circuit Board Replacement: paso 4, imagen 1 de 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Circuit Board Replacement: paso 5, imagen 1 de 2 Nortel Networks i2004 IP Circuit Board Replacement: paso 5, imagen 2 de 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Circuit Board Replacement, Circuit Board: paso 6, imagen 1 de 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Circuit Board Replacement: paso 7, imagen 1 de 2 Nortel Networks i2004 IP Circuit Board Replacement: paso 7, imagen 2 de 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Circuit Board Replacement: paso 8, imagen 1 de 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Circuit Board Replacement: paso 9, imagen 1 de 2 Nortel Networks i2004 IP Circuit Board Replacement: paso 9, imagen 2 de 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Circuit Board Replacement: paso 10, imagen 1 de 3 Nortel Networks i2004 IP Circuit Board Replacement: paso 10, imagen 2 de 3 Nortel Networks i2004 IP Circuit Board Replacement: paso 10, imagen 3 de 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Circuit Board Replacement: paso 11, imagen 1 de 2 Nortel Networks i2004 IP Circuit Board Replacement: paso 11, imagen 2 de 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Circuit Board Replacement: paso 12, imagen 1 de 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Circuit Board Replacement: paso 13, imagen 1 de 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
Conclusión
2 personas más completaron esta guía.
Elizabeth
Miembro Desde 01/21/12
160 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-35, Amido Winter 2012 Miembro de Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 2,164
