Introducción
This guide will show you how to remove and replace the battery.
Partes
No se requieren partes.
Flip the Nook over.
  • Flip the Nook over.
Agregar Comentario
Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present. Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
  • Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Remove the two T5 Torx screws securing the back cover.
Remove stickers covering T5 screws and remove screws
badbyz - Contestar
Also, remove the mini SD card first or you may break it taking the back off.
54pontiac - Contestar
Insert the flat end of a spudger between the front panel and the rear assembly. Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Use a spudger to lift the the back panel from the rest of the Nook.
Agregar Comentario
Slide the spudger around the edges of the Nook to loosen the back panel. Slide the spudger around the edges of the Nook to loosen the back panel.
  • Slide the spudger around the edges of the Nook to loosen the back panel.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the back panel off the Nook.
  • Pull the back panel off the Nook.
Agregar Comentario
Remove the ten T5 screws from around the edges of the silver midframe. Remove the ten T5 screws from around the edges of the silver midframe.
  • Remove the ten T5 screws from around the edges of the silver midframe.
Agregar Comentario
Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
Agregar Comentario
Lift up the foam pad at the corner of the battery to reveal the battery connector. Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
  • Lift up the foam pad at the corner of the battery to reveal the battery connector.
  • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
Agregar Comentario
Lift up the foam that covers the power connector and volume connector.
  • Lift up the foam that covers the power connector and volume connector.
  • Disconnect the power and volume cables from their sockets on the motherboard.
Agregar Comentario
Carefully lift the silver midframe away from the motherboard and display assembly. Carefully lift the silver midframe away from the motherboard and display assembly.
  • Carefully lift the silver midframe away from the motherboard and display assembly.
Agregar Comentario
Set aside the motherboard and focus on the metal backing containing the battery. It is not necessary to remove the battery to replace the display.  Move on to Step 11. Use the screwdriver or plastic prying tool around the edges of the battery to pry it from its slot in the metal backing.
  • Set aside the motherboard and focus on the metal backing containing the battery.
  • It is not necessary to remove the battery to replace the display. Move on to Step 11.
  • Use the screwdriver or plastic prying tool around the edges of the battery to pry it from its slot in the metal backing.
  • The battery may be held with adhesive. Do not panic if it feels like you are prying too hard just apply some force until it is no longer stuck.
  • Pick up the battery and remove it making sure to free the cords in the upper left hand corner by sliding it out rather than lifting it.
It is not necessary to remove the battery for screen replacement
badbyz - Contestar
Great instructions but where do I get a new screen from?
rightfootscorer -
I love your site!! THE REPAIR MANUALS ARE FANTASTIC. I THINK I CAN REPLACE MY NOOK BATTERY BY MYSELF!!thx
edwardstorer - Contestar
When replacing the motherboard make sure that the speaker assembly component (small rectangular piece) is in place. It is not attached and needs to be properly aligned.
  • When replacing the motherboard make sure that the speaker assembly component (small rectangular piece) is in place. It is not attached and needs to be properly aligned.
Agregar Comentario
Conclusión
12 personas más completaron esta guía.
Holly Lowe
Miembro Desde 26/09/12
208 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-4, Propen Fall 2012 Miembro de Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Miembros
7 Guías creadas
How does one disconnect the battery connection in Step 8? The photo shows it miraculously disconnected and the head of a flathead screwdriver is visible, but it doesn't show how to actually remove that connector which has some sort of interlock. Do you just pry the connector away or do you pry it up? The new battery connector has the same interlock, but gives no clue as to how one would make or remove the connector.
jjsims - Contestar
what a bullsh*t way to screw the public….ugh. sticking to fricking books!!!! no battery needed!!
iblobar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 9
Últimos 7 Días: 62
Últimos 30 Días: 325
Todo El Tiempo: 32,761
