Introducción
This guide will show you how to remove the back cover revealing the battery. This will allow you to access the inside of the nook tablet and will act as prerequisite for most of the other guides
Partes
No se requieren partes.
Flip the Nook over.
  • Flip the Nook over.
Agregar Comentario
Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present. Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
  • Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Remove the two T5 Torx screws securing the back cover.
Remove stickers covering T5 screws and remove screws
badbyz - Contestar
Also, remove the mini SD card first or you may break it taking the back off.
54pontiac - Contestar
Insert the flat end of a spudger between the front panel and the rear assembly. Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Use a spudger to lift the the back panel from the rest of the Nook.
Agregar Comentario
Slide the spudger around the edges of the Nook to loosen the back panel. Slide the spudger around the edges of the Nook to loosen the back panel.
  • Slide the spudger around the edges of the Nook to loosen the back panel.
Agregar Comentario
Pull the back panel off the Nook.
  • Pull the back panel off the Nook.
Agregar Comentario
Conclusión
To reassemble your device, line up the piece that was removed with how it was on before and then just firmly press down till it snaps into place.
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 1-4, Propen Fall 2012 Miembro de Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 5,013
