Saltar al contenido principal
Nokia N70 Speaker Replacement
Qué necesitas
  1. Nokia N70 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Speaker Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the phone.
  5. Nokia N70 Speaker Replacement, Keypad: paso 5, imagen 1 de 3 Nokia N70 Speaker Replacement, Keypad: paso 5, imagen 2 de 3 Nokia N70 Speaker Replacement, Keypad: paso 5, imagen 3 de 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Speaker Replacement: paso 6, imagen 1 de 3 Nokia N70 Speaker Replacement: paso 6, imagen 2 de 3 Nokia N70 Speaker Replacement: paso 6, imagen 3 de 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Speaker Replacement, Speaker: paso 7, imagen 1 de 2 Nokia N70 Speaker Replacement, Speaker: paso 7, imagen 2 de 2
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
  8. Nokia N70 Speaker Replacement: paso 8, imagen 1 de 3 Nokia N70 Speaker Replacement: paso 8, imagen 2 de 3 Nokia N70 Speaker Replacement: paso 8, imagen 3 de 3
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
  9. Nokia N70 Speaker Replacement: paso 9, imagen 1 de 3 Nokia N70 Speaker Replacement: paso 9, imagen 2 de 3 Nokia N70 Speaker Replacement: paso 9, imagen 3 de 3
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
Conclusión
Justin
Miembro Desde 10/12/11
984 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-2, Regan Fall 2011 Miembro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 4,082
