Partes
No se requieren partes.
Orient the phone as shown.
  • Orient the phone as shown.
  • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Agregar Comentario
Remove the battery cover by lifting it away from the phone.
  • Remove the battery cover by lifting it away from the phone.
Agregar Comentario
Insert the plastic opening tool into the marked space.
  • Insert the plastic opening tool into the marked space.
  • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
Agregar Comentario
Remove the battery from the phone.
  • Remove the battery from the phone.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Insert the plastic opening tool in the marked areas in between the front and back covers. Pry each corner with the plastic opening tool until the front case completely detaches. Pry each corner with the plastic opening tool until the front case completely detaches.
  • Insert the plastic opening tool in the marked areas in between the front and back covers.
  • Pry each corner with the plastic opening tool until the front case completely detaches.
Agregar Comentario
Orient the phone so that the keypad is facing you. Remove the keypad by lifting it away from the phone. Remove the keypad by lifting it away from the phone.
  • Orient the phone so that the keypad is facing you.
  • Remove the keypad by lifting it away from the phone.
Agregar Comentario
Using a torx T6 screwdriver remove the six 15 mm torx screws.
  • Using a torx T6 screwdriver remove the six 15 mm torx screws.
Agregar Comentario
Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle. Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
  • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
Agregar Comentario
Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect. Remove the ribbon connection that connects the two circuit boards.
  • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
  • Remove the ribbon connection that connects the two circuit boards.
Agregar Comentario
While pulling back each of the clamps marked in the image, lift out each side of the screen independently. Be careful when using the plastic prying tool to not scratch the display. Be careful when using the plastic prying tool to not scratch the display.
  • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
  • Be careful when using the plastic prying tool to not scratch the display.
Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Justin
Miembro Desde 12/10/11
924 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 6-2, Regan Fall 2011 Miembro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 22
Todo El Tiempo: 6,808
