Partes
No se requieren partes.
Orient the phone as shown.
  • Orient the phone as shown.
  • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Agregar Comentario
Remove the battery cover by lifting it away from the phone.
  • Remove the battery cover by lifting it away from the phone.
Agregar Comentario
Insert the plastic opening tool into the marked space.
  • Insert the plastic opening tool into the marked space.
  • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the battery from the phone.
  • Remove the battery from the phone.
Agregar Comentario
Insert the plastic opening tool in the marked areas in between the front and back covers. Pry each corner with the plastic opening tool until the front case completely detaches. Pry each corner with the plastic opening tool until the front case completely detaches.
  • Insert the plastic opening tool in the marked areas in between the front and back covers.
  • Pry each corner with the plastic opening tool until the front case completely detaches.
Agregar Comentario
Orient the phone so that the keypad is facing you. Remove the keypad by lifting it away from the phone. Remove the keypad by lifting it away from the phone.
  • Orient the phone so that the keypad is facing you.
  • Remove the keypad by lifting it away from the phone.
Agregar Comentario
Using T6 Torx screwdriver remove the six 15 mm torx screws. Using T6 Torx screwdriver remove the six 15 mm torx screws.
  • Using T6 Torx screwdriver remove the six 15 mm torx screws.
Agregar Comentario
Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle. Remove the front panel by lifting the panel away from the phone at a 45 degree angle. Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
  • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
Agregar Comentario
Locate the rear circuit board by flipping over the front panel. Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot. Caution: Be careful when prying camera out of the slot for the connections are fragile.
  • Locate the rear circuit board by flipping over the front panel.
  • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
  • Caution: Be careful when prying camera out of the slot for the connections are fragile.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Justin
Miembro Desde 12/10/11
924 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 6-2, Regan Fall 2011 Miembro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Miembros
10 Guías creadas
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 17
Todo El Tiempo: 8,185
