Saltar al contenido principal
Nokia Lumia 635 630 Display Assembly Replacement with Frame
Qué necesitas
Resumen del Video
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: paso 1, imagen 1 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: paso 1, imagen 2 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: paso 1, imagen 3 de 3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 2, imagen 1 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 2, imagen 2 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 2, imagen 3 de 3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 3, imagen 1 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 3, imagen 2 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: paso 3, imagen 3 de 3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: paso 4, imagen 1 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: paso 4, imagen 2 de 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: paso 4, imagen 3 de 3
    • Put the earpiece on the new display assembly and start with reassembling.
Conclusión
17 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,308 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,532 Guías creadas
2 comentarios
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Contestar
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 10,325
