Saltar al contenido principal
Nokia Lumia 620 Volume and Power Button Replacement
Qué necesitas
  1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: paso 1, imagen 1 de 1
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Nokia Lumia 620 Volume and Power Button Replacement: paso 2, imagen 1 de 1
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Nokia Lumia 620 Volume and Power Button Replacement: paso 3, imagen 1 de 1
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Nokia Lumia 620 Volume and Power Button Replacement: paso 4, imagen 1 de 2 Nokia Lumia 620 Volume and Power Button Replacement: paso 4, imagen 2 de 2
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Nokia Lumia 620 Volume and Power Button Replacement: paso 5, imagen 1 de 1
    • Gently release logicboard connectors
  6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: paso 6, imagen 1 de 2 Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: paso 6, imagen 2 de 2
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  7. Nokia Lumia 620 Volume and Power Button Replacement: paso 7, imagen 1 de 1
    • Check connections of failed buttons
  8. Nokia Lumia 620 Volume and Power Button Replacement: paso 8, imagen 1 de 1
    • Resolder broken connections
    • Make sure the pads do not short
  9. Nokia Lumia 620 Volume and Power Button Replacement: paso 9, imagen 1 de 1
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  10. Nokia Lumia 620 Volume and Power Button Replacement: paso 10, imagen 1 de 1
    • Reconnect logicboard connectors
  11. Nokia Lumia 620 Volume and Power Button Replacement: paso 11, imagen 1 de 1
    • Put back plastic cover
  12. Nokia Lumia 620 Volume and Power Button Replacement: paso 12, imagen 1 de 1
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
Linea de Meta
11 personas más completaron esta guía.
Anne
Miembro Desde 10/17/14
456 Reputación
1 Guía escrita
4 comentarios
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Contestar
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Contestar
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Contestar
Omg it looks complicated
Maz Hanvey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 10,170
