Introducción
If your front screen has stopped working and you need a new one, this guide will show you how to access the front screen.
Partes
Start with the phone in the flipped open position.
  • Start with the phone in the flipped open position.
  • You must remove the sticker in the center, below the screen to reveal the center screw.
  • Use a T5 screwdriver to remove all three screws, loosening the front screen.
Agregar Comentario
Flip the phone to the closed position and turn to the front screen. The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  • Flip the phone to the closed position and turn to the front screen.
  • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
With the front cover off, the screen and keypad should be loose.
  • With the front cover off, the screen and keypad should be loose.
Agregar Comentario
Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone. With the cable disconnected, the screen should be free for removal or replacement.
  • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
  • With the cable disconnected, the screen should be free for removal or replacement.
Agregar Comentario
Conclusión
In order to reassemble the front screen or install a new screen, follow the steps provided, in reverse order.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 18-21, Garner Spring 2011 Miembro de Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 13
Todo El Tiempo: 5,086
