Saltar al contenido principal
Nokia 8290 Microphone Replacement
Qué necesitas
  1. Nokia 8290 Microphone Replacement, Front Cover: paso 1, imagen 1 de 3 Nokia 8290 Microphone Replacement, Front Cover: paso 1, imagen 2 de 3 Nokia 8290 Microphone Replacement, Front Cover: paso 1, imagen 3 de 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Microphone Replacement, Circuit Board: paso 2, imagen 1 de 3 Nokia 8290 Microphone Replacement, Circuit Board: paso 2, imagen 2 de 3 Nokia 8290 Microphone Replacement, Circuit Board: paso 2, imagen 3 de 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Microphone Replacement: paso 3, imagen 1 de 3 Nokia 8290 Microphone Replacement: paso 3, imagen 2 de 3 Nokia 8290 Microphone Replacement: paso 3, imagen 3 de 3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Microphone Replacement, Microphone: paso 4, imagen 1 de 3 Nokia 8290 Microphone Replacement, Microphone: paso 4, imagen 2 de 3 Nokia 8290 Microphone Replacement, Microphone: paso 4, imagen 3 de 3
    • Use the spudger to peel back the top-left corner of the white adhesive film. This can be done by working the spudger back and forth underneath the film.
  5. Nokia 8290 Microphone Replacement: paso 5, imagen 1 de 3 Nokia 8290 Microphone Replacement: paso 5, imagen 2 de 3 Nokia 8290 Microphone Replacement: paso 5, imagen 3 de 3
    • Continue to peel the film back until you can see the microphone.
    • Use tweezers to remove the microphone.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 15-3, Benson Fall 2012 Miembro de Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 333
