Introducción
How to remove the speaker.
Partes
No se requieren partes.
Turn off the cell phone.
  • Turn off the cell phone.
Agregar Comentario
Press down on the round button on the back cover of the phone.
  • Press down on the round button on the back cover of the phone.
Agregar Comentario
Slide the back cover down while still pressing the button.
  • Slide the back cover down while still pressing the button.
Agregar Comentario
Remove the back cover.
  • Remove the back cover.
Agregar Comentario
Press the end of the battery towards the top of the phone.
  • Press the end of the battery towards the top of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift the battery outwards while still pressing it upwards till it pops out.
  • Lift the battery outwards while still pressing it upwards till it pops out.
  • You may need to take several attempts to lift out the battery.
Agregar Comentario
Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • This step may be a bit difficult if you are removing the antenna for the first time.
Agregar Comentario
Pry open the antenna door by pulling down the top of the spudger
  • Pry open the antenna door by pulling down the top of the spudger
Agregar Comentario
Remove the antenna door.
  • Remove the antenna door.
Agregar Comentario
If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
  • Try to keep the antenna as flat as possible. Do not bend it.
Agregar Comentario
Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
  • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
  • The two bottom screws are longer than the upper three.
Agregar Comentario
Remove the back covering.
  • Remove the back covering.
Agregar Comentario
Remove the two screws at the top.
  • Remove the two screws at the top.
Agregar Comentario
Remove the metal plating and the circuit board.
  • Remove the metal plating and the circuit board.
  • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
  • The LCD will be attached to the circuit board.
Agregar Comentario
Remove the speaker.
  • Remove the speaker.
Agregar Comentario
Conclusión
Aaron Jen
Miembro Desde 11/04/10
1 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 27-94, Amido Spring 2010 Miembro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,929
