Introducción
How to remove the gold patch antenna.
Partes
No se requieren partes.
Turn off the cell phone.
  • Turn off the cell phone.
Agregar Comentario
Press down on the round button on the back cover of the phone.
  • Press down on the round button on the back cover of the phone.
Agregar Comentario
Slide the back cover down while still pressing the button.
  • Slide the back cover down while still pressing the button.
Agregar Comentario
Remove the back cover.
  • Remove the back cover.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Press the end of the battery towards the top of the phone.
  • Press the end of the battery towards the top of the phone.
Agregar Comentario
Lift the battery outwards while still pressing it upwards till it pops out.
  • Lift the battery outwards while still pressing it upwards till it pops out.
  • You may need to take several attempts to lift out the battery.
Agregar Comentario
Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • This step may be a bit difficult if you are removing the antenna for the first time.
Agregar Comentario
Pry open the antenna door by pulling down the top of the spudger
  • Pry open the antenna door by pulling down the top of the spudger
Agregar Comentario
Remove the antenna door.
  • Remove the antenna door.
Agregar Comentario
If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
  • Try to keep the antenna as flat as possible. Do not bend it.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Aaron Jen
Miembro Desde 11/04/10
1 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 27-94, Amido Spring 2010 Miembro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,075
