Saltar al contenido principal
Nokia 6350-1b Display Screen Replacement
Qué necesitas
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: paso 1, imagen 1 de 2 Nokia 6350-1b Display Screen Replacement, Display Screen: paso 1, imagen 2 de 2
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move the plastic pry along the frame unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry too hard, doing so could crack the plastic frame.
  2. Nokia 6350-1b Display Screen Replacement: paso 2, imagen 1 de 1
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move along this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Display Screen Replacement: paso 3, imagen 1 de 1
    • Disconnect the flex cable from the logic board.
    • Disconnect the LCD display screen.
    • Remove the LCD display screen from the rest of the device.
  4. Nokia 6350-1b Display Screen Replacement: paso 4, imagen 1 de 1
    • Connect the new LCD display screen to the phone.
    • Reconnect the Logic Board to the flex cable.
  5. Nokia 6350-1b Display Screen Replacement: paso 5, imagen 1 de 1
    • Using the T-5 screwdriver, screw the four screws back into the phone.
  6. Nokia 6350-1b Display Screen Replacement: paso 6, imagen 1 de 1
    • Place the cover back on the device so that it is in the correct position to be reinstalled.
    • Press gently on the cover so that it snaps back into place.
Conclusión
Una persona más ha completado esta guía.
Anna
Miembro Desde 04/13/12
21 Reputación
2 Guías creadas
Equipo
SUNY Cortland, Team 1-2, Getto Spring 2012 Miembro de SUNY Cortland, Team 1-2, Getto Spring 2012
SUNYCORT-GETTO-S12S1G2
2 Miembros
8 Guías creadas
Un comentario
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 1,850
