Introducción
The back cover and the battery have to be removed before the SimCard can be reached. No tools are required.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Turn the phone so it is face down (keypad side is down).
  • Turn the phone so it is face down (keypad side is down).
Agregar Comentario
Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
  • Press and hold the button located at the bottom of the phone.
  • Slide the back of the phone downwards and away from the main body.
  • Remove the backing and place it to the side.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
  • Locate indentation from which battery can be removed.
  • Place finger in indentation and lift battery up from phone's body.
  • Remove battery from phone's body.
Agregar Comentario
Push the SimCard towards the bottom of the phone.
  • Push the SimCard towards the bottom of the phone.
Agregar Comentario
Slide finger underneath top of SimCard. Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
  • Slide finger underneath top of SimCard.
  • Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
Agregar Comentario
Pull up on the SimCard and remove it from the back of the phone. Place the SimCard to the side.
  • Pull up on the SimCard and remove it from the back of the phone.
  • Place the SimCard to the side.
Agregar Comentario
Conclusión
To insert a new SimCard, simply push the card in as shown in step 6, and snap it in place.
Reid Polstra
Miembro Desde 22/10/12
1 Reputación
7 Guías creadas
Equipo
Clemson, Team 15-5, Benson Fall 2012 Miembro de Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 602
